Adam_H
Dec 10, 2015Explorer
Common issue that could cause stalling is the PCV elbow at the back of the throttle body. Follow the line up from the valve cover and feel if the elbow is collapsed. 10 minutes to check and no scanner needed. Unless you have a "heated" pcv the part is cheap.
Adam
Adam
44,070 PostsLatest Activity: Sep 18, 2026
