jspringator's avatar
jspringator
Excursion dies upon abrupt stop.
My V10 X dies sometimes upon an abrupt stop, or right after shifting into reverse. It doesn't do it every time, but a couple of times a day. It doesn't die when slowly decelerating up to a stop light.
Any ideas?
  • Turtle n Peeps wrote:
    jmckelvy wrote:
    I assume it is gas powered? If so remove the Idle Air Control Valve on the throttle body and clean with carb cleaner. Also clean the throttle body and any passages associated with the IACV.
    This is where I would go first.
    That fixed my 4.6 Modular V8 in my Fabulous Town Car from a very similar issue… Only difference was mine would howl like a trumpet, and die, and idle rough.
    Just a hint… disconnect the battery before you replace the IAC…
    Could also be a fuel filter.. chances are you need to replace it anyway.
    Thanks!
    Jeremiah
    x2. My former work truck, a Ford Ranger developed an issue where it would not idle at all and it turned out to be a bad idle air control valve.
  • Carburetor shot and you need a new transmission.
    Not really, plug into that baby and see what it's doing.
  • I assume it is gas powered? If so remove the Idle Air Control Valve on the throttle body and clean with carb cleaner. Also clean the throttle body and any passages associated with the IACV.
