The_LeRoys's avatar
The_LeRoys
Excursion v10 Tow Rating Question
So on the tow ratings guide, it shows the tow ratings of a 2005 Excursion V10 as 11,000 lbs. It doesn't clarify if that is with the 3.73 or 4.30 gears. I have seen some people on here mention its lower with 3.73. What is that limit and where do you find it?
What is the cost to change the gears on a 4wd X? Is $1500 about right?
Does the 7.3L Diesel have the same restriction on tow capacity for the gears?
