Gonecamping444
Feb 12, 2015Explorer
Exhaust Brake
Just got a new pickup with exhaust brake on it,I was told that some people keep it on all the time,What's the reason for that?Thanks
Sport45 wrote:Cummins12V98 wrote:Sport45 wrote:
I didn't advocate towing without the exhaust brake. Just think turning it on every time you're behind the wheel is a waste.
That's my opinion and I'm stick'n to it. :)
Does your truck have an exhaust brake?
No it doesn't. But the one I'm ordering this year will.
My opinion (and it's only an opinion) stands. It's based on what I've learned through reading about light duty truck EB's.
My gas engine has pretty effective compression braking. I don't advocate using compression braking (downshifting) every time you want to slow down either even if it does make brake pads last longer.
wintersun wrote:
Laziness or stupidity. It provides zero benefit with no load and zero benefit on level ground or on uphill sections and the benefit going downhill depends on the load and the grade. Only an idiot would leave it on all the time when it is only going to provide a benefit 1% of the time.
On a 5% or greater downgrade that goes for miles and with a tow load of more than 4,000 lbs. the exhaust brake does help to keep the speed of the rig down with little or no use of the brakes (tow vehicle or trailer).
Clearly they need a truck manual for dummies.
N-Trouble wrote:ScottG wrote:
On new trucks it moves the impellers on the turbo to create the back pressure. If you don't use it often enough they get clogged up with carbon and eventually stick.
I have head this as well but believe it to be a myth...
Just watching my turbo vane position in my Edge CTS without the exhaust brake on its all over the place based on output demand. Its not like without the EB on its not ever going fully open or close.
One negative aspect of using around town is that you have to remember your BRAKE LIGHTS do not come on when the EB engages. So if you have it set aggressively and someone is tailing you just be prepared.
wintersun wrote:
Laziness or stupidity....
