NRALIFR
Jan 21, 2019Explorer
Those are SLA AGM batteries, and as long as it’s a 12 v battery your solar controller should be OK with it. As small as it is AH-wise though, you may not get much jack operation out of it even with shore power plugged in. When I’m lifting my camper with shore power connected, I’m still seeing about 3 amps coming out of the battery. That’s with a much bigger AGM battery that can hold the voltage higher under load for a longer period of time, and a PD4645 converter charger.
What type of shore power converter charger does your camper have?
44,066 PostsLatest Activity: Apr 16, 2026
