peoples1234 wrote:
So my question is, would LT tires help with this problem? I have the factory P tires on there aired up to max pressure (50 lbs).
Basically, is there a drastic difference between a P and LT.
Yes ! Stiffer sidewalls and heavier load rating. I would look for tires with >116T load rating (Michelin LTX). This is what is on my daughter's 2012 Expedition.
Higher profile (65-75 series) tires will also have stiffer sidewalls.
Do you have the factory HD trailer tow option ? You can always add the HD radiator and extra transmission cooler. Good piece of mind.
