mileshuff wrote:
Thsldo wrote:
The new durango is actually longer and wider then the previous gen.
Just looked up specs on both my 2004 and the newer 2014 Durango's. The 2004 is slightly wider, taller, longer and more ground clearance. I'm also seeing quite a bit more interior space, legroom, head room, etc. in the older version. I'm using Edmunds online specs for both. Parked next to a newer D and the older looks quite a bit bigger but could be an optical illusion since the new D's are more rounded and streamlined contours.
I apologize, for some reason I thought for sure the new one was longer and wider, it's just the wheel base that is longer, and only by 1/2 an inch. Sorry for providing wrong info!
