theoldwizard1
May 06, 2018Explorer II
Ralph Cramden wrote:
You don't mention the brand. When most claim "Azdel" what they don't bother to mention is where they used Azdel. Hardly any use it everywhere. It's a lot of marketing hype. You also said "rear wall". On a lot of trailers the rear wall is not a laminated assembly like the sidewalls but simply a layer of filon hung on a substrate.
Key words here are that the "skin" (possibly Filon ?) has delaminated from the "substrate" (Azdel ?, luan ?) The failure is likely not because of the substrate.
If it is delam on a new rig the only true fix is having it returned to the factory for wall replacement. Anything else is a band aid fix and I for one would not accept it on a new rig.
Concur ! The sad news is, this will likely take weeks before you get your unit back from the factory !
