Jframpey wrote:
Here's another possibility... Water pressure coming into the trailer is fine. But, the water heater warms the water causing expansion, with the check valve preventing back flow into the water hose - the weakest link bursts.
You basically have a closed system, check valve on the hose inlet, and a check valve on the pump... You need a leaky faucet! Or an expansion tank, or a relief valve. I have an expansion tank.
Joe
Yep, water doesn't compress. It's gotta go somewhere.
We never leave the hot water heater on if not being used. Waste of propane, expansion issue, and it's noisy.
