powerliftingtex's avatar
May 19, 2022
Extending Camper Tounge?
I have a 10' Bass Raider boat with a little 4 horse and do a ton of fishing, nearly 3-days a week and love the convenience of throwing the little bass boat in the bed of my 6.5' Super-Crew, obviously with some over-hang.
Now that we got the kiddo, and take a camper with us, I don't have enough clearance to turn. I need at least another 3'.
Obviously adding extensions or stacking extensions would be too dangerous and add too much stress on the tounge.
I'm thinking cutting my RV frame and re-welding a longer tounge is going to be my only option...
Anyone had this problem? If so, what did you use? C-channel? Tubing? Angle? Obviously the cost of metal is through the roof right now, but I don't want to cheap out on safety.
  • OK, now it makes sense. A TT behind a pick up. I would build a bolt on extension that fits alongside the tongue U bolting to the existing frame and into the 2" hitch reciever of the trailer extending as much forward as you need. No need to cut the TT frame just make an adaptor for length. Got one for my 20' flat bed that allows me to carry 24' steel pipe and tube with out overhang.
  • I think I may have messed up and posted this in the wrong section. I'm a newbie with RV'ing so please excuse me if so!
    My camper is a tow behind camper (Riverside Retro) and my towing vehicle is a F-150 SuperCrew. My boat is a small 10' bass boat that I slide in the bed of the truck.
    My camper has a dry weight of about 2500 lbs. I'm worried about adding "Hitch Extensions" due to them compromising my hitch tounge weight capacity. With that said, instead of extending the hitch and putting more pressure on the tounge, I was considering extending the front trailer hitch by a few feet using some square tubing or C-Channel. (I have a 240v stick welder.)
  • My post might have added to the confusion. I referred to TC towing with extensions was for extension info only. The link is from the TC section , regarding hitch ext’s.
    Im under the impression that the OP is now using his MH to tow his boat bc he needs more room bringing his child on fishing trips.
  • I think we might need a little bit of clarification. You're posting in the Class C motorhome forum, you mention a pickup, and taking a "camper". When I see "camper" I think a slide in camper that goes on a pickup. Do you have a motorhome? If so, just use a hitch extension. That little boat doesn't weigh enough to make any difference. If you were towing something heavy you'd want to rethink that. No need to cut the RV frame. Or are you going to carry the boat on the back of the RV? Or are you towing a trailer with the boat in the back of your truck?
  • The tongue weight that you are considering is not much TW. Either extend the trailer portion of the hitch or add an extension to the MH.
    Been there , have done it both ways. Have no preference of one or the other. I did it with a lot more weight that you are talking about.
    Many TC guys have to use hitch extensions bc of the rear overhang of the truck camper over the pickup.
    hitch extension thread
