old_guy
Jun 18, 2014Explorer
many good ideas above. if you do the vent thing I would put a barrier behind the vent screen or you may lose the integrity of the TT insulation. you get any moisture in there the insulation will shrink and you will have a cold spot. if you do the electrical insert, they cost and arm and a leg. just make sure you seal the patch, no matter which sealing method you use. good luck.
44,066 PostsLatest Activity: Jul 25, 2018
