msue's avatar
msue
exterior refrigerator fan
Last year when I camped in 100+ weather, my refrigerator really had a hard time keeping the temp below 40degrees. I had a little fan in the frig but it wasn't enough. I was told to put a fan outside in the refrigerator area so it would vent to the roof. I was told to get a computer fan and rig it up. Any other suggestions?
  • Use these thermistor fans...built in thermistor so fan is temperature controlled. Best way to wire is direct to battery 12 volt.
    htsSilenX Effizio Thermistor EFX-12-15T 120mm Case Fan
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835226045&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Case+Fans-_-N82E16835226045&gclid=CJi6z-_Q_LYCFQNlMgod8H8AqQ
  • Computer muffin fans are cheap and reliable. If you have a bit of wiring knowledge it should be a simple choir to wire one up. Finding a small temp switch should be easy also to wire into the circuit.
  • Seems like I saw one that was solar powered some where...always thought that might work better. Would run during the day with the sun and pull the heat out off the fridge vent area outside....keep the air moving...
  • Hi Msue,
    I'd get two and make a mask so they will draw air up the chimney. It is nice to add a thermostat, too.
