Hemi_Joel
Apr 02, 2020Explorer
Your connection of the 110v feed from the inverter needs to be isolated from shore power and generator power in a 100% failsafe method. The easy way is to run some outlets (Additional new or re-wired existing) that are dedicated to the inverter. When the inverter is in use, plug into them. When not, plug into the others.
Or else you can do it with an additional automatic transfer switch. There are articles online how to rig up automatic transfer switches in pairs to isolate and prioritize the power source that is feeding the coach wiring. Shore, gen, or inverter.
