srschang
Apr 03, 2020Nomad
Added a small single breaker box and moved the converter 110v supply from the power center to the breaker box. Then wire the breaker box to shore power before the transfer switch so it will only run from shore power.
Didn't take the time to move the A/C ahead of the second transfer switch. Figured if I turn on the A/C while running on the inverter and run my batteries down, I'm a dummy. Best way would be to also move the A/C out of the power center and into it's own breaker box (or with the converter in a small box that will handle more than 1 breaker) ahead of the transfer switch.
