Kayteg1
Nov 21, 2019Explorer II
jimh425 wrote:Kayteg1 wrote:
There is big difference between 18" and 48" extensions.
The bending forces are 7 times multiplied between the 2 and that's why you need superhitch for long one.
Can you explain your math? Also, why does it matter for flat towing?
You know it's been about 40 years since I study construction calculations and I moved to different trades.
So the 7 times was "shoot from the hip" but you are free to do you own calculations to compare.
Here is a link you might use
When flat toad towing brings less vertical stress to the hitch, my reply was intended for understanding how much difference extending the hitch makes in real life.
you can say that adding 30 more inches is not big length, but it makes whole new mountain in bending and shearing forces.
44,071 PostsLatest Activity: Aug 16, 2026
