joe_julie81
Nov 22, 2019Explorer
By extra long I just mean longer than the standard short bars you buy at Walmart. Maybe 16-18inches should work fine stand alone. Someone mentioned earlier using chains - I assume with rings welded to the ball end of the bar to attach turnbuckles to rings also maybe welded to the truck's frame rails (using turnbuckles or chains) to shore up the side to side torquing? That may not be necessary with a relatively light toad, 4 down?)
44,071 PostsLatest Activity: Aug 16, 2026
