joe_julie81's avatar
joe_julie81
Extra long towbar instead of supertruss mod?
I'm considering towing a Jeep Wrangler, probably 4dr, with my rig listed here (weight 4000-4500 lbs). Is there such a thing as an extended towbar for towing a vehicle that's not real heavy in lieu of adding the supertruss receiver hitch to extend the drawbar out the 18 inches that my tc overhangs? As long as the towed vehicle trails far enough behind the truck/tc rig it should be alright for turns? Anybody using interchangeable towbars of differing lengths, determined by what the toad is being pulled by?
  • I would think the bar would need to telescope in at least 3 stages to get the overlap for side loads, and be able to be stored under the camper. Don't think I would want to hook up under the camper very often. Better to mount the bar before load the camper, then to hook up swing bars out and telescope to pin to toad.
  • I have never seen toad with long tongue that would reach under camper, but I observe toads behind diesel pushers, who have hitch about the same distance behind rear axle what long TC do and almost all toads fishtail.
    So IMHO if don't mind crawling under camper for hookup, the idea of long tongue should work better than stinger.
  • Do you really need a Super Truss hitch for a toad?
    I think an 18" hitch extension would be fine for a toad.
    There's really no tongue weight with a toad.
    I would do a couple of chain side supports off the extention.
