mike-s wrote:
RinconVTR wrote:
It takes more effort and pressure to push grease thru a zerk fitting than it does thru the EZlube system!!!!
So what? Either can exceed the pressure the seals can handle.
I couldn't find any good reference, but you claim to know. How much pressure does it take to push grease through the EZ-Lube system, under what conditions, and what's the source of your information?
Prove it to yourself, in a very crude by feel method only.
- Operate the grease gun handle normally, nothing attached
- Attach an loose grease zerk to the gun, pump again
- Now pump the EZlube
Result...all the same.
Finally, something else I have tested and also made a mistake with on trailers (utility and boat) that have bearing buddies (spring loaded, holds a light constant pressure when loaded correctly) is I overfilled them. A couple times on purpose, but before that by mistake.
I mention this because in doing so, you will find for yourself how much grease gun handle force is required to push out an axle seal. Its uncomfortably high and you will quickly learn any more pressure than pumping thru a bare zerk is too much.
The EZlube flow thru hole is significantly larger than zerk fittings and there is no where for pressure to build up with the rubber cap removed. It is 100% impossible to blow out a good working seal via EZlube zerk.
