Perrysburg Dodgeboy wrote:
Where are you getting the Ecodiesel @ 27mpg? "And as we found, its EPA ratings of 24 mpg combined (21 mpg city, 29 mpg highway) actually underrate its fuel efficiency at highway speeds. The heart of this truck is what gives it the EcoDiesel badge: parent company Fiat Chrysler's 3.0-liter turbodiesel V-6 engine, which you can add to just about any Ram trim level.Apr 27, 2016"
That is what the rating is for the 4WD Ram Ecodiesel since I was comparing it to a 4WD Colorado. The 2WD Ram Ecodiesel is rated at 28 mpg and the 2WD Colorado is rated at 31 mpg. If you actually want to get technical, the onlt Ecodiesel that is rated at 29 mpg highway is the HFE version which is only 2WD, can only be had in a base Trademan quad cab configuration, and only comes in a 3.55 gear ratio bringing its towing capabilities down considerably. Ram's very own website states this. The regular non-HFE Ecodiesel 2WD is rated at 28 mpg while the 4WD is rated at 27 mpg. The 2WD Colorado is rated at 31 mpg and the 4WD is rated at 29 mpg.
Again, the Colorado gets better fuel mileage. I don't know why it would be so hard to understand that a lighter and smaller trucks with a slightly smaller diesel would get better fuel economy that a bigger vehicle.
2WD Colorado 22/25/312WD HFE Ram 1500 21/24/29Regular 2WD Ram 1500 20/23/28------------------------------------------------------------------
4WD Colorado 20/23/294WD Ram 1500 19/22/27Perrysburg Dodgeboy wrote:
I'm now pulling down 32/33 on the highway do to the tune on my truck. You do know the GM only has a six speed and the Ram has a 8 speed RRRIIIGGGTTT :R Also if the GM weights less it would all be relative as both engines are most likely working as hard given the size & weight of each truck.
And I am pretty sure that if you do the same kind of modification to the Colorado then it would also increase its fuel mileage.
OK we get it YOU don't like small displacement diesel engines so WTF are you on a post talking about them? As for pricing I would hope a smaller truck cost less! I priced out a Canyon SLT as close as I could get it to my truck and it was $4K less but without all of the Laramie's options. The GM only has 5/60,000 powertrain coverage the Ram has 5/100,000 can't find any exact numbers for the curb weight of the GM diesel but I bet it is within 1000# of the Ram.
It is not that I don't like small displacement diesels, I just think they belong in a smaller midsized truck and not a full size. A full size should have a larger diesel with greater power output. Maybe a 4.0L with about 300 hp and 500 lb-ft.
Also, you invited us to speak here since you called us out with your "For the guys that where slamming Ram for going with the VM 3.0 in house diesel", "Ford is going with a 3.0 diesel made by Range Rover owned by Tata Motors. "(which is false) and "Let the spinning begin boys lol". Now you keep rebutting me trying to tell me that a heavier larger truck with a bigger engine gets better fuel economy that a smaller and calling out the numbers I am posting as false so I am responding to those rebuttals with facts.
