ryanb-72's avatar
ryanb-72
F-150 towing
I am sure this is not news to a lot of you but if you are towing with an f-150 check to see that you have the relay and fuse installed for charging your camper battery.
I came across this info in another forum and was less than impressed when I went and checked only to find I have not been charging my battery while going down the road.
Ford chooses to leave out the relay and fuse for battery charging for some reason. I even have the factory installed brake controller that works just fine.
The relay goes into slot #9 and the fuse #21.
Just thought I would throw this out there in case I'm not the only one that had no idea.
Ryan
  • Ford has been doing it that way as long as I can remember, and I'm old.
  • More than likely it is covered in the owners manual and it appears that Ford supplies the parts
  • We had the exact same thing come up just a few weeks ago....we've had the F-150 since '03!!! DH was going nuts trying to figure out what the problem was and envisioned all sorts of dreadful things. Can't remember who it was that mentioned it - maybe the Auto Zone guy - but he swapped one from another location and Bingo!....just a few dollars and we were much happier. Now, why did Ford install the factory tow package and neglect this little matter???
  • My special order 2001 came the same way. Parts in a bag in the glove box.
    Inserting the relay and fuse has been a long time honored tradition to drive a Ford.
  • Ford is not the only one to do that. When I bought my Chevy, I found that my Brake Controller worked but no brake lights and no battery charging. As you stated, it was missing a fuse but had the relay installed but it had to be turned around and re-inserted to work. Go Figure.
  • RoyB
    Thank You! I thought I had checked. I had found a camera cap for tailgate camera but that was it. After reading your post I went and took everything out of glove box and there it was under everything.
    Still wish I had known sooner. Live and learn I guess.
  • RoyB's avatar
    RoyB
    Explorer III
    I found mine in an unmarked plastic pack in my glove box on my 2010 F150.
    Had no idea what they were for.
    Finally figured it out when I was looking at the fuse panel under the hood. Found the slots marked 'trailer charge' or something like that and was missing fuse and relay.
    Roy Ken
