ib516's avatar
ib516
Explorer II
May 30, 2019
F150 2.7 EB vs 5L V8 towing mpg
The 2.7 EB truck had a 3.55 axle, the 5.0L had a 3.31, both 10 speed auto crew can 4x4s, towing a 7000# horse trailer.
The 5.0L V8 rated at 395hp/400tq did 9.8 mpg
The 2.7L EB rated at 325hp/400tq did 8.8 mpg
They said the 2.7L "felt like" a better performer. Could be due to elevation.
  • If at elevation, the eco boost may have been making more power. It very well could have held speed better.
  • APT wrote:
    Was average speed higher for 2.7L? I expect the Ecoboost maintained speed better in combination with what @ShinerBock listed for effective displacement/fuel
    Not likely or perhaps even possible with less power by such a margin.
  • Lots of missing details, otherwise the MPGs are out of context
    Gassers are designed for stoichiometric ratio during open loop and when up to temp, closed loop can vary +/- depending on both temp and whether oxygenators are in the fuel
    What is the elevation ?
    What is the boost ?
    What is the throttle position ?
    What are the gear ratios from the tranny to the diff and to pavement vs ICE RPMs at the pavement
    Stuff like that is missing...else comparing apples to oranges...IMHO
  • Was average speed higher for 2.7L? I expect the Ecoboost maintained speed better in combination with what @ShinerBock listed for effective displacement/fuel
  • Doesn't surprise me. The 2.7L Ecoboost has a greater effective displacement at full boost(moving as much air as a 5.9L) and is able to move more air at altitude than the 5.0L. The more air you add the more gas you need to keep it around a 14.7:1 air/fuel ratio which lowers fuel economy but increases performance.
