Blanch wrote:
I need some opinions on the F150 as a 5th wheel puller. I am looking to upgrade my TV. I have a 03 Duramax.
If needing justification for a new TV...check your budget for the tens of thousands of bucks this will cost vs sunk cost of what you have
Refreshing stuff will be...should be less money and again if just wanting to justify a new vehicle...that is each individuals choice
{I don't think I can afford to go diesel again. Looking at the F150 as a tow and be our main vehicle.
Suggest you do the simple math on both your current TV and any proposed TV.
First, decide if you believe in the OEM ratings system or not.
If yes, then suggest looking mainly at the RGAWR for comparison. Typical half ton RGAWR ranges from +4K GAWR to just below 5K GAWR...whereas your current TV should have an approx 7K RGAWR....that will be the most limiting rating between the approx 14 different half ton F150's vs any of the higher class TV's and their +6K RGAWR's
What are the opinions on F150 as a puller?
My opinions above and note that I keep my vehicles till the wheels fall off and some will say older, so lower ratings...yup...the metrics for comparison of today's half ton vs higher class still apply...just that they are all rated higher today because of more mature science/technology and design...
Thanks
