jaydub74 wrote:
APT:
According to the brochure the Max Towing, HD Payload with 6.5 box Super Crew has 2310 lbs of payload and 8200 GVWR and 11,300 lb tow rating.
Caution: that's the absolute MAX payload you can get in that configuration. Any options from the base model will drop that often by a couple of hundred pounds, depending. I got lucky and was only 50# less than the max catalogue payload because of the 20" wheels.
Still, HD Payload is enough for most bumper-pulls unless you are carrying a lot in the truck. You will run up against the max 1150# WDH hitch receiver rating next.
