Scrooge39
Nov 28, 2014Explorer
"Battery boost" question
Looking for an explanation……….
Last week we decided to go camping. Motorhome had not been started in a month. Also, the previous 2 nights got into the low 20s so decided to plug block heater in (Cummins ISB). Got all loaded up and after about 2 hrs. attempted to start the engine. Turned key and had 2 “growls” and then engine would not turn over. Waited about a minute or so and tried again, nothing. I then depressed the “bat boost” switch and tried to start again but had the same results, nothing. I checked the operation of the “bat boost” contactor and it was working as I could hear it energize when the switch was depressed. The house batteries were fully charged as I leave the motorhome plugged in. Put a battery charger on the chassis batteries for about an hour and tried the above again with the “bat boost” but still had nothing. I then decided to call my road service. After a few minutes a tech came on the line and I explained all of the above to him.
He then wanted me to try one more thing. He said get in the motorhome and hold the “bat boost” switch down for 1 minute but do not try to start. After 1 minute he told me (still depressing the “bat boost” switch) to try to start the engine. Turned the key and the engine turned over and fired right up. He could give me no explanation as to why the “bat boost” switch had to be held down for a minute so he apparently had run into this situation previously.
So, perhaps someone can enlighten me as to what transpired for that minute the “bat boost” switch was held on and the house/chassis batteries were “shorted” together to allow the engine to turn over.
Thanks, Richard
Thanks, Richard
