wdgold
Jul 23, 2017Explorer
F150 Fx4
Anyone out there pulling a 5ver with a F150 Fx4 screw with 5.4 Thinking of going with a slightly heavier unit than I had.
MFL wrote:wdgold wrote:
My Payload is 1300#, my guess is If I don't exceed that with pin weight, fuel, passengers etc I should be fine correct?
Yes, that is correct. However, you will not find much of a FW, with less than 1300 lbs loaded pin wt. If you can stay under RAWR/tire ratings you may get by with the 150, but not really the right tool for the job.
Jerry
