Ahowell
Apr 25, 2014Explorer
F150 or F250
My husband and I have been looking for the perfect travel trailer for about 6 months. We found one two weeks ago and were so excited for our first family camping trip in a TT and not a tent. Before we...
kaydeejay wrote:Michelle.S wrote:Not going to find GCWR on any label on the truck, that number is in the Owner's Manual.
OK, first off, put down the owner's manual and go to the truck and open the Driver's door. There should be several labels/stickers on either the edge of the door or on the door pillar. Write down those numbers, especially the GVWR, GCWR, and GAWR Rear, there should also be numbers for the Max Cargo cap. Then do the same for the label/sticker on the front drivers side of the TT. With those numbers in hand, come back here and post them, then folks will be able to help you determine where your problem is.
As has been said already, if the truck has the tow package, then an auxiliary transmission cooler should be there.
I hope the weights are in line or the OP may have a fight with the dealer and/or Ford over whether the trans is covered under warranty.
