goducks10 wrote:
The Screw with 6.5 bed has the thicker frame material as the HD Scab 8' bed. Also the HD has the 4800 RAWR, so if the part #'s are the same then the Screw Maxtow with 6.5 bed should have the 4800 RAWR. Doubt it does as the axles would be different to accommodate the 7 lug wheels. IIRC there are different bushings and what not as well on the HD.
All good points. looking at Fords fleet builders specs shows:
... The HD package has the 4800 RAWR 9.75" rear axle.
... The MAX package has the 4050 RAWR 8.8" rear axle.
... 1.33" dia axles with 34 spline for the 9.75" axle in the HD.
... 1.29" dia axles with 31 splines in the 8.8" axle in the MAX.
The 7 lug HD wheels are 2400 lbs rated vs 2025-2100 lbs for the others.
The 8200 GVCWR HD package is set up to carry more weight but tow ratings are similar to the MAX tow.
