Marshmallow256
Sep 14, 2018Explorer
Groover wrote:
Since you are going to be mostly on flat ground weight really isn't the issue, frontal area wind drag is. This camper may have a lot more wind drag than your boat. Also, campers seem to get a lot more wind induced sway than boats and have electric brakes instead of surge brakes. Since you are willing to slow down some that can help a lot with the wind drag. Beware of sway and do you have a brake controller for the electric brakes? Remember that a light touch on the electric brakes will get most sway under control if that becomes an issue.
My boat has a massive t-top and a huge bow flare, but it ties nicely. It’s trailer does have electric brakes, since I don’t like surge. My work trailer also has electrics. I installed a tekonsha p3 when I bought the truck back in 15. The truck has the electronic sway control, although I have no idea how it works.
Also, it has load range E tires. I replaced the factory ones at 10k since they had a lot of sidewall flex.
44,025 PostsLatest Activity: Feb 18, 2025
