philh's avatar
philh
Explorer III
Oct 19, 2019
F150 Tire time
50k miles going into winter, wear bars are a little too close for comfort. Truck came with Michelins, they are adequate.
4x4, snow, highway, rain, and towing.
Fav brand and types?
  • A set of OE takeoff tires off Craigslist is where I'd be, if I just wanted another set of fresh treads and enjoyed the performance characteristics of the original tires. Save ya about 50% minimum doing that.
  • Had a set of Yokahama YK-HTX on my `13 F-150 that I was on 73K miles before I traded it off. Got less than 50K on the OEM Michelins plus they were about $200 cheaper than the Michelins.
  • My F150 came with Michelins and I’ve had them on other types of vehicles too. Very happy with them and will continue with them, but I live in Florida and don’t have to worry about snow and ice.
  • I just got a set of Pathfinder AT tires from Discount Tire. They are the 275/55/20 OEM tire size. XL load rating (#2800 @ 50 psi).
    More than enough load for an F150 with only a rear GAWR of #4050.
    Anyway, first time I've not gotten Les Schwab tires.. Saved about $400 in the process too and still have the same tire warranty as LS gives..
    Time will tell I guess, but so far, I like the tires and can't wait to tow with them.
    Good luck!
    Mitch
    :) Hi, my F-150 has 49,500 miles on it so I'm in the same place as you. Mine came with Goodyear Wranglers LT load range "C". I believe that I will most likely go with the same tires. I don't want or need load range "E" and there doesn't seem to be very many choices in "C".
  • Nv_Guy's avatar
    Nv_Guy
    Explorer III
    I like Michelins (just put a set on my F250), but I had Goodyear Wranglers on my F150. Worked great in the snow.
    If the Michelins lasted 50K and they worked, why not go back to Michelins?
  • Terramax high treads or h/t. Good all around tire. I buy them from Les Schwab but I think it is a bit cheaper if you order from Walmart online to the store.
