Volkov
Aug 09, 2016Explorer
F150 vs 250
Considering replacing the old girl - 04 8.1 Yukon XL as her electrical gremlins and module failures are becoming increasingly frequent. Plan 1 had been max payload SCrew with max tow pkg but then saw...
Powerdude wrote:I have found that to be true for a long time now. Those F150's are rediculously expensive, while the bigger trucks are similar and less, as long as you don't get the diesel.
I just got a F250 gas crew cab, outgoing model year (see my sig). It was cheaper than most current production F150 crew cabs with aluminum body by about $3k.
Yes, it's less efficient on gas, by about 3-4 mpg, but $3k can buy a lot of gas.
I'm sure some will want to argue, but in the exact same trim (XLT) and options, the F250 was cheaper by $3k, at 6 different dealers. Plus, it has way more payload (3k lbs), and more towing capacity (12k vs 11.3k lbs).
For me, it was a no-brainer.
