ib516
May 14, 2014Explorer II
Ahowell wrote:
That's what the sticker on the window says BUT it states two different axel ratios as did the Fords and Chevys. When I questioned salesmen at ALL dealerships they didn't know why the axel ratio was different on the sticker. For example under Standard equipment it lists 3.73 under customer preferred package it states 3.42
Yes, thats because dual rear wheels (and 3.73 gears) are standard on the 3500, and if you "delete" the drw option with the customer preferred package xxx, you get a single rear wheel, and therefore 3.42 in the srw. No matter, it'll pull just fine! Its rated to tow over 17,000 lbs as is.
44,068 PostsLatest Activity: Jun 14, 2026
