8iron wrote:
IdaD wrote:
I didn't realize the 2015 F150 payloads went quite that high. If you check each of the right boxes you can get a 4wd SuperCrew "long" bed up to 2650 lbs of payload. That's impressive for a half ton. In fact that's higher than a Ram 2500 CTD in the same configuration.*
* Which, obviously, is going to be a superior tow vehicle despite being rated lower.
Yep, they can get up there in payload and have for a few years now with the HD pkg. My question is are they readily available or strictly special order? I have yet to find one on a lot or even with an inventory search on Ford.com or .ca. (But I haven't tried that hard)
Which is great, but I was just fiddling around on Ford's website and once I checked all the right boxes I could still walk off the lot with a comparably equipped 6.4 Ram 2500 for less money. I'm sure the 6.4 would burn a little more fuel but I doubt it would be all that material in the overall scheme of things, and you would get quite a bit more capability with the Ram. It would have a little bit rougher ride and wouldn't be quite as fast, but those don't seem like big trade-offs relative to what you would get in return.
