MFL
Jan 26, 2015Nomad II
If you had the 4.30s, it would be no problem at all.
You will likely have to lock out 6th, towing in 5th should work on the flats most of the time. In a strong wind you may be towing in 4th, but should be do able.
If 2wd, it would not cost that much to change gearing, if you feel the need.
Good luck,
Jerry
Good luck,
Jerry
