8iron
Feb 11, 2015Explorer
dodge guy wrote:
The rear axle gears will effectively change the ratio of each gear in the transmission. Lower axle gears will make each gear more effective in moving a given load.
Yes but with 6 gears(or 8 or 10 in some cases) to choose from is the difference in rear end ratios really that black and white as with the old 3 speeds?
