dragr1
Dec 14, 2017Explorer
Dave H M wrote:
Well I am going to have do a little surmising here. :h I tow a 10K ish fifth wheel with a 6.2 CC SB that has a 4.30 diffy. I was not in as time crunch like you so waiting 8 weeks for the truck to get here was not s problem.
This year I will be running 3 times thru the Smokies so will get some grunting time in like on the Saluda grade.
Personally I think you will be running mostly 5th gear. That may not a bad thing though. I have found that the 6.2 needs a few R's to make any ponies and it starts to bog in 6th anywhere under 2000 R's.
So I think you will get along OK with the 3.73 if you are not expecting to chug along in 6th and say cruise at 60 mph.
Rpm's don't bother me, I don't run in 6th gear with them manual either unless I'm on the interstate on really flat ground, 60mph or under is always in 5th even with the Cummins
44,066 PostsLatest Activity: Jul 25, 2018
