Grit dog wrote:
JIMNLIN wrote:
JD5150 wrote:
I could be wrong but I think my 2017 SRW F350 has a bigger rear axle tube than the 2017 SRW F250.
I have the gas 6.2, crew cab, long bed with max payload 4160
 Yeah the gas F250 gets a smaller axle dia vs the F250 diesel. It gets the same axle as F350 srw. Axles don't carry  weight...just twist the gears/axles.
 That  4160 lb payload is a gvwr based payload and will have to be spread over FAWR/RAWR. The F250 gas or diesel simply doesn't have enough RAWR to carry 4160 lbs in the bed.
OMG.  You actually contradicted yourself in the same response.
Axles DO carry weight, as a unit.  If they didn't, the axle weight rating wouldn't matter and you could put a little 8.8 axle under a F250 gasser because it's not going to twist it apart.
RAWR = REAR AXLE WEIGHT RATING.  Not RATR (rear axle toruqe rating)...
 Actually a full floater axle shaft does not carry weight which is the subject being discussed with the OP... not the axle as a unit. The F250 gasser gets a smaller axle shaft diameter than the F250 diesel which is also what I was responding to with the OP.
    The OP F350 srw has the same axle diameter as the F250 with the diesel. So he is thinking right about the larger axle shaft diameter being a better choice when running those larger diameter tires when he goes off road and has to hammer it.
