YellowLightning's avatar
May 24, 2020
F250 Payload Capacity
I am looking at buying a used F250 but the door sticker seems to have a lot lower payload than I thought it would have. The truck fits the price range my wife and I are in. We are looking at a 1995 Hallmark, model number 4026-9HM. We will probably strip it down and rebuild it as simple and light as possible. Want to have a front hitch for bikes and will occasionally tow a small boat.
Specs of the truck are 2013 F250 XL w/power locks/windows/mirrors, 6.2L V8, 4x4/FX4, ex-cab, 8' bed. Payload capacity of 3016lbs, GVWR 10000lb, Front GAWR 4800lb, Rear GAWR 6100lb. It had a 3 leaf rear leaf spring and no auxiliary upper leaf. Factory tire pressure of 75PSI front and 80PSI rear. It sat very tall for a F250. With that GVWR, I would think the payload would be higher. Am I assuming too much to think it should have a higher payload?
Is this a good truck or should I hold out for an F350? Could I bring it to a heavy truck shop and upgrade the suspension and apply for an official payload re-certification? Or just buy it, load it up, and get on the road?
  • Where's my popcorn??
    Considering 3/4T is 1500lbs a payload of over 3000lbs is not bad at all.
    Personally, I'd check the tire ratings and upgrade them as needed and load it up and get on the road.
    Others will tell you that you need a 1T DRW with 14,000 GVWR to carry that (any!) camper.
    - Mark0.
    (PS: there is no way to magically or otherwise change the trucks factory payload sticker, you ether pay attention to it, don't or get a truck with different values)
