wing_zealot wrote:
harmanrk wrote:
Actually I'm looking at a F250 PDS to pull a 7600 pound hybrid, so hardly looking for a minimum vehicle. I was more looking at 5th wheel capacity for 'the next trailer', and found it odd the the 5th wheel capacity was less than the bumper capacity. But as it comes down to the amount of the trailer weight carried as tongue weight, that makes more sense.
You know your towing capacity (i.e.: payload) goes way down with the diesel?
So if your thinking 5th wheel you might want to think F350 or make sure you have enouh payload capacity for whatever size of fiver you think you might end up with.
Pop Quiz: Do you know where to find the "real life" payload rating of any truck you test drive, on the lot, as it sits? (Hint: the answer is not the salesman)
Yes, I am well aware that the diesel is heavier than the gas engine. however that has nothing to do with what I ask (an anomaly where the 5th wheel capacity is lower than the conventional capacity) does it?
I am also well aware of the door/frame sticker with the information about the particular truck, are you aware there are thousands of 5th wheels being pulled by 150/1500 trucks every weekend? I do realize there are some who would recommend nothing less than a freightliner to pull a popup.
