Denny & Jami wrote:
I've driven a Ford V10 with 3.73 gears and 4.30 gears and all the way through the gears the 4.30 wins hands down, I have friends with 6.7 Fords with 3.54 and 3.73 gears again the lower gears win. One of my Ford trucks with a 460 I changed from 3.73 to 4.10 night and day difference pulling the same load.
The 6 speed makes a dig difference because the second OD keeps the rpm down when cruising down the road in 6th pulling because the final gear ratio puts more available power to the ground.
No what is said the final mechanical advantage (rear gears) makes the difference, just go to any truck specs and see what happens to the towing capacity increases with lower gears.
Denny
The reason the specs go up with lower gears is because of duty cycle. It has nothing to do with gears making power........they don't. The same thing with HP. The reason they derate a 4 or 5 series truck engine is because of duty cycle.
Like I said, if you don't believe me just go dyno your truck and see what happens when dyno'ed in a lower gear. The fact is, a lower gear WILL reduce the power to the ground, not increase it. That is a engineering certainty.
