bigfootgrey wrote:
You could go with pressure treated or marine plywood and a bed mat. Costs more but less likely to warp or rot
Bob
Typical pressure treated plywood warps worse than BB/MDO/HDO due to less plys and for some reason green treated lumber seems to warp more in general than kd lumber.
But it will still work. If you want plywood that won't warp, use the above types of from ply I mentioned. It'll probably outlast you.
So will stall mats. Idk why NL would post that. Unless they're maybe really slippery on the bottom. But there's easy fixes for that too.
