Buzzcut1 wrote:
2 Piece wrote:
Siletzspey wrote:
FYI. In the NL Owners Manual is "We recommend the use of a soft rubber bed mat (3/8”) max thickness be installed directly under the bottom of every camper. This helps prevent the camper from sliding in the box. Thicker horse stall type mats do not work as well and will cause the camper to move." I have also seen at least one other camper manufacturer recommend against horse stall mats.
--SiletzSpey
Dang it! I was just getting ready to go to Tractor supply and get 2 stall mats! I had dreams of leaving the mats in the truck and how easy it would make loading and unloading once I got back from trips!
I have had horse stall mats under my camper for 9 years. The camper doesn't slide around and I don't need to remove them when the camper is not in the bed
Do you have 2 layers of horse stall mats or just 1 layer?
