bigcitypopo
Jun 18, 2013Explorer II
Not every beach is the same... Silicate content and water content is different. I can drive in my beach at almost 30 PSI. And then go ten miles south and have to be near 20. Grover beach I have to be really low 15psi or so...
The key is to see how the tide line runs and try to drive to the tide line in a straight line... Little to no turning as it digs the tires....
I worked on the beach with a heavy jeep, it was a pain.. Your f350 has a wider stances than the jeep and has wider tires.... More weight too... I always keep 2x8 s in the truck so if I need to I can plank my way out of a rut.... 3.5-4ft sections will get you near the top of most ruts.. As long as you aren't throttle heavy
