the_bear_II
Feb 06, 2015Explorer
It depends on the weight ratings and load. If you watch a few Fords and Chevys/GMCs (F350 or 3500s) going down the road with TT and or 5th wheels some sag and some don't.
I'm guessing if you were able to find a Ford and GM with identical weight capacities and towed the same trailer with both (an apples to apples comparison) both would sag equally or not sag.
Your best bet is to determine what load you will be carrying and then get a truck that has more than enough capacitiy for the load. The worst truck you can get is one that is at (or over) maximum capacity when loaded.
44,056 PostsLatest Activity: May 04, 2014
