Mike3
Jun 21, 2014Explorer
F450 Fiver Bed - Will This Fit A TC?
Hi all, I've been considering a TC for sometime now and I've decided to pull the trigger if one will work with my current truck. I have a 2004 F450 4WD with a Fontaine Classic Hauler Bed designed for towing a 5th wheel. The truck only has 60K on it and is used mostly for pulling a 36' HitchHiker.
My concern is the design of the bed may not allow for proper fit of the TC. The closest TC dealer is nearly 200 miles away so I'm hoping to get some insight from you guys before making that drive.
I don't see an option here to post a pic so I'll describe it.
1. The exterior width from fender to fender is 95.5". A Lance dealer told me over the phone that the inside measurements of the jacks are 99". Is that about the same for all duallies?
2. The bed depth is only 12.5" which is much shallower than a normal pickup bed. Will that be an issue?
3. The bed does not have a tailgate. Instead it has a U shaped cut out for the kingpin to pass thru. Will a side door or some other style TC work with this.
4. The bed is made of fiber glass. In place of a bumper the fiber glass is molded so that if flares out at the bottom and provides a step in the center. The outside of this step extends about 12" from the interior truck bed.
5. The bed is standard size about 66" wide and a little over 96" long.
What do you think? Thanks everyone!
