philh
Sep 29, 2019Explorer III
F450 vs F350
How bad is the ride on the unloaded 450 when compared to the 350? How is it with the 5th attached? Does the turning radius improvement make up for the comfort difference? We're about two years ...
philh wrote:Cummins12V98 wrote:
"Does the turning radius improvement make up for the comfort difference?"
Can't say that a turning radius is top of my list as it's not often it comes into play.
350 and 450 are both 14k GVWR, it you believe you should not exceed that number the 350 will give more carrying capacity before hitting the magical number.
I should be easily in DRW, SRW is questionable. Although the 2020 SRW published payload numbers are looking much better.
