GDS-3950BH
Dec 14, 2020Explorer
kellem wrote:
Yep, foam flooring.
It's actually used by several manufacturers in 4-season trailers for it's insulation value.
Problem is, over time can show travel wear which is exasperated by occupants body weight.....yes it actually has a weight limit that's not disclosed.
Our last 2 trailers were foam flooring without issues but we tippy toe.
Its actually used in 75% or more of trailers, most advertised or claimed to be lightweight, 4 season has little to do with it.
The foam compresses or loses its bond to the thin plywood resulting in the soft area and flexing. Add to that some manufacturers use a minimal number of aluminum tube in the assembly which may be as far apart as 4' on center or further.
Keystone does not vacuum bond those panels, they use a pinch rolling system, two different processes and vacuum bonding is much better. Even the manufacturers who vacuum bond have issues. Some Forest River brands such as Rockwood/Flagstaff have recently went back to plywood/OSB floors due to the number of issues. Its common with laminated floors.
Unless they completly disassemble the trailer and replace the entire floor, any repair will be cobbled together. Even then, if they replace the bad floor with the same type of assembly, chances are it will happen again.
44,071 PostsLatest Activity: Aug 23, 2026
