bucky
Feb 05, 2017Explorer II
You Ram guys need to remember if you must leave it idling put it in neutral with the e brake on. Check your manual if its a 07 and a half or newer but from the 48RE back the trans does not circulate fluid in park. There are valve body mods out there to correct this but stock you can burn it up with excessive idling.
