blt2ski
Feb 06, 2017Moderator
Some of you are forgetting about the old 2cycle detroits with wet? sleeved cylinders. If you did not warm them up before a hard start, the cylinder would come out! THAT is and only HAS been the reason from what I have heard to truly warm up a diesel.
For some, yes, overnight sleeping in a cab. But as noted, one needs to keep the motor at a higher then normal low idle.
I've never generally speaking let any of my now about 6 different diesels to idle at start up for long. My equipment will idle per say for 5-10 minutes. but that is so the hydraulic oil etc warms up. The motor, start up and go generally speaking.
Trains, some boats etc, they leave the motors when stopped, so the units have AC power, due to many being a diesel run generator. WHile the diesel needs to run, the generator runs the AC and DC with in the unit. So shutting them down is not always in the best interest of ALL involved.
Marty
Marty
