Hannibal
Feb 12, 2017Explorer
Cummins12V98 wrote:Hannibal wrote:
With my four Cummins powered Rams and their properly located post turbo pyrometers, driving around town seldom required more than a minute idle time to safe shutdown temp. While towing, by the time I coasted into a rest area or down an off ramp to get fuel, I was already at a safe temp before coming to a stop. In the campgrounds, less than a minute or two at the most.
Even back in the previous century, Cummins recommended not idling for extended periods as it can cause cold combustion and cylinder washdown, stuck rings and clogged injectors. Truckers let them idle to keep themselves warm at night, not the engine.
My diesel pickups were no more of a big rig then than my 5.4L F250 is now. Not even with the towing mirrors out when I'm not towing anything is it a big rig. No need to pretend it is.
Now if I could add a compressor and solenoid to sound like air brakes when I come to a stop, that would be a whole different story! :B
Post turbo properly located? I and many on the TDR would disagree with that. Post turbo is too slow to respond to what is happening.
Buy a 3pc exhaust manifold where is it tapped for the probe?
Properly located according to Cummins. The exhaust elbows on my four Cummins was bolstered and dimpled specifically for drilling and installing a probe. I have the first issue of TDR. I was a member when it was a mailing list registry before the first issue. The proper location to monitor for shut down temps is post turbo. The turbo is a heat sink and can stay hot longer than exhaust gasses pre turbo. Pre turbo is for monitoring exhaust gasses in modified engines to prevent overtemp of combustion chambers. It may be more entertaining pre turbo and necessary for bombed diesels but, it's not reliable for shut down temps.
