PhilR wrote:
My 2 year old Fantastic Fan stopped working. Checked fuse- OK, but replaced anyway. No luck. My unit doesn't have a remote and the thermostat is a dial on the fan unit. Any suggestions...is there something simple that I'm missing? Thanks.
I had my speed dial go out. Check to make sure you have 12v at the fuse. If you do, then most likely it is either the speed dial or switch that makes sure the lid is open. Pull it apart and check that you have 12v on both side of the switch that activates with the lid opens and closes. Then check that you have 12v on one side of the speed dial. Then turn it to full speed and you should have 12V on the other side of the speed dial.
